any SUV guys with rear coilovers?
Old Jan 5, 2016 | 07:18 PM
mikeyjm1's Avatar
Default any SUV guys with rear coilovers?
I already did the front with Atomic's brackets. Who has done the rear? How'd you do it?
Old Jan 7, 2016 | 06:04 PM
Tig's Avatar
Tig
I know of one who did it to a TBSS. He basically removed the shock and stuck a coil over in its place. The only problem with that is its not the correct angle. I believe it should not be any more than a 20 degree angle max.
What is your drop height up front with your coil overs?
Old Jan 7, 2016 | 06:44 PM
mikeyjm1's Avatar
I'm not even sure. It was cranked up for so long that I never could figure out what height to put it back to. Then I went to the coilovers and I have no clue. Just set it in the middle of the QA1 DS301's. Been a while since I measured and I'm deployed right now so again Im just not sure.
I'd like to do McG spindles and maybe a longer shock/spring with a custom shock hoop for more travel. Then drop the rear on coilovers to match.
Old Jan 7, 2016 | 07:55 PM
Tig's Avatar
Tig
Gatcha, man you need to spend more time home, hah
Sounds like you want a pre-runner set up, haha. I wonder how you'd go about doing that? Since the shock/strut mount is the coil mount as well. It would have to be cut out, correct?
I do like the sound of it
djfilletteLSX
Feb 13, 2016 02:10 PM
bpope
Jan 3, 2016 03:54 PM
Alco
Dec 23, 2015 09:07 PM
Blwn99x
Dec 21, 2015 03:06 AM
Mainesfinest
Dec 11, 2015 02:45 PM
