Any manual tranny LSx swap gurus out there?
Been thinking about this...
Since the gray CPP clutch wire is normally open, I think I have to hook it to a wire supplied with 12V at all times (not leave it unhooked) in order to effectively bypass the starter interlock.
Right?
Jake
Right?
Jake
I believe you are right, the first time my master cylinder broke, I tried unplugging the clutch switch, so I could start the truck, and it wouldn't work, I ended up taking the switch apart, and moving the spring so it held the switch closed instead of open, that allows me to start in gear, but I can't use cruise control.
Thanks,
Jake
I also didn't try to use my CC when I was driving with the switch locked closed.so it might work, but I doubt it, because it will turn off any time I push the clutch in. I was more concerned with driving 45 miles home from work with no use able clutch.
I was thinking of just installing a few pin switches somewhere on the linkage with a manual bypass for clutch-free starting like so:
Think that'd work?
Jake
Think that'd work?
Jake
grantpo
07-15-2015 12:21 PM
