Any difference in 4l60e- car/truck?
Old Oct 8, 2005 | 02:24 PM
Eye-P's Avatar
Default Any difference in 4l60e- car/truck?
I am looking to replace my now FUBAR 4l60e with a GMPP 4l60e. The part number is- 12497318.
The local GM parts guy says this is a Corvette transmission. Is this case any different than a truck case? Longer or shorter maybe?
Old Oct 8, 2005 | 03:31 PM
The tailhousing might be different, I am not for sure.
Old Oct 8, 2005 | 05:05 PM
Mr. Sandog's Avatar
That one should work, the spline count needs to be correct (I think it's 33), but the 24221888 (4L65E) is supposedly a Corvette transmission as well, and worked fine in my truck.
The 24221888, BTW, is only about $350 more, and is significantly upgraded. Have you seen this article?
Old Oct 8, 2005 | 06:00 PM
99Silver6.0's Avatar
Tail housing AND the shift rod that sticks out the side of the tranny. It is short on the f-body trans and longer on the truck. I had to swap the rods before I could put the module on the side of the tranny.
Old Oct 8, 2005 | 06:12 PM
Eye-P's Avatar
So for the most part, this is a easy swap then?
Old Jun 17, 2006 | 11:38 AM
GoatChs's Avatar
Hey guys...I can get a great deal on a near new Dr. Evil 4L60E from an 04 GTO. Want to install it in my 01 Yukon (has a 02 LS1 5.7 in it). From what I read here, I can swap the tailhousing and shift rod from my oem 4L60E to the DrEvil 4L60 and bolt it up?
Old Jun 17, 2006 | 04:40 PM
litreddevil's Avatar
Banned
some of the y and f bodys the bell houseing is different also it all is on what input shaft it has
Old Jun 17, 2006 | 04:47 PM
FLT's Avatar
FLT
FormerVendor
Yes this all will work however the is a sleeve on the output shaft for your vented yoke that will need to be swaped as well.
Old Jun 18, 2006 | 12:08 AM
GoatChs's Avatar
Thanks Vince...I appreciate and value your input on this. I guess that it would be best to purchase a new sleeve rather than using the 85k mile unit in the existing tranny?
Old Jun 18, 2006 | 12:19 AM
FLT's Avatar
FLT
FormerVendor
If you can get it off with out hurting it you'll be alright. Use a flat blade screw driver and hammer. Gently tap it on differnt sides untill it comes off and then install it on to the other shaft. Pretty simple. There is a seal in this sleeve if it is hard or leaks it should be replaced. I have plenty of them laying around if anyone needs one.
twake_410
Apr 14, 2016 09:58 PM
wickedRCSB
Oct 30, 2015 09:45 PM
Staggered 02
Oct 9, 2015 05:19 PM
gmcyukon
Oct 5, 2015 06:20 AM
sTNT971
Sep 26, 2015 06:27 AM
