another tranny ?
Old Apr 30, 2008 | 10:12 PM
ramsey rider's Avatar
Default another tranny ?
hey guys ,i just installed my new 60 e ,its got all flt parts and goodies in it,including 5 pinion planets etc.heres the deal,its flaring between gears.sometimes real high..1-2 is ok,but the rest are flaring bad.any ideas?thanks ahead.actually i wanted too correct that its mostly 2-3 flare up the rest are descent .could be alittle harder but wth.
Old May 1, 2008 | 06:07 AM
nothing?.vince you there?
Old May 1, 2008 | 07:35 AM
bump4 me
Old May 1, 2008 | 01:33 PM
still nothing ,this sucks ,all this money and still have an issue.help me out here guys..thanks ahead.
Old May 1, 2008 | 04:11 PM
is it flaring and hittin the rev limiter if so its probably time to move up to a 4l80e i bet your makin to much power for a 60e built or not .
Old May 1, 2008 | 08:41 PM
naa its not hitting the limiter iits just flaring between 2-3 the rest are alll good.this is a good solid tranny.i dont THINK ill blow it in 1 day.plus the truck is running like a pig not making alot of power rght now .ill deal with that after the tranny issue.any more suggestions guys?so far ive heard ,take the synthetic fluid out ,install a vaccum mod ,and raise the pressure on the epc.what do yas think here?
Old May 1, 2008 | 09:21 PM
gottago's Avatar
i had mine built about the same way, mine just shifted vary hard, it went about 600 miles and it burned up the linings in every gear. took it to a differnt shop and they told me i had to have a vacum mod in it. so thay rebuilt it and it shifts alot better now. i guess the computer can back the line presser way down.
Old May 1, 2008 | 09:54 PM
fastnblu's Avatar
School me. What is flaring?
What does the vac mod do that corrects this issue?
Old May 1, 2008 | 10:11 PM
gottago's Avatar
then the tranny just uses vac instead of the pcm to control the shift firmness. its just like the old school tranny then. if you have a shift kit the line presser is way higher then normal and the computer will try to back it down.
Old May 1, 2008 | 10:34 PM
fastnblu's Avatar
So the vac would override pcm in terms of that, & load that it sees would be how it's controlled, right? I'm done w/ having these 4L60E's shift hard. Just a lil firmer would be fine. No more... this way.
