another one bites the dust
Old Apr 23, 2012 | 09:01 PM
pillittokillit04's Avatar
Default another one bites the dust
This will be tranny #5 it was a built 4l60e and either looking to get one from FLT/rpm/or rossler. But on the other hand curious about the 80e swap. How much is the swap. I believe I can get a computer already programmed from Nelson and get used 80e w verter. Can I use the crossmember out of the HD truck and just order a harness?
Old Apr 23, 2012 | 10:04 PM
slammedsilvy's Avatar
I bet you would have less in an 80e swap with a shift kit than another built 60e, and it doesn't appear the 60e will last in your truck. If I were you, I would have swapped after the first failure. Do it and don't look back in my opinion.
Old Apr 24, 2012 | 06:58 AM
00buckshot's Avatar
80e swap and breathe easy everytime you mash the skinny pedal
Old Apr 24, 2012 | 09:54 AM
OL' MAN's Avatar
Man, I can't believe you've gone thru four 60's and would even consider trying another one!
When I did my 4l80 swap, just the core cost $750, rebuild cost $1350, sc2800 yank converter was right at $1050 w/shipping. Don't forget you'll need the 4l80 flex plate and spacer for the swap unless you get a 'verter lugged and drilled for your 4l60 flexplate.
And you'll need to get some mod/shortening/rebalancing work done to fit a 1350 u-joint/
4l80 yoke on the front of your driveshaft (mine cost $160).
Nelson has a really good step by step write-up on the conversion over on ls1truck, check it out. It even shows how to modify your existing crossmember to work with the swap if you have access to a welder and chopsaw/torch. It's much cleaner imo than trying to modify an hd crossmember because of the difference between the height of the frame rails between the 1500 and 2500 trucks.
Old Apr 24, 2012 | 10:22 AM
nonnieselman's Avatar
yea, dont feel bad, it took me a year and quite a few 60Es to figure out i should go 80E.
i think i had about $900 in my whole swap. It was easy, and i have a writeup in the transmission section on how to do the wiring for it.
Old Apr 24, 2012 | 10:40 AM
Well its either get one from rpm for trans and converter for 3100 shipped or do the swap its my dd so down time is an issue
Old Apr 24, 2012 | 10:44 AM
80E swap
Old Apr 24, 2012 | 08:54 PM
swift700's Avatar
Do the swap, it's easy and if you have the parts you can do it in a weekend by yourself. A little welding experience is helpful for the x-member.
Old Apr 25, 2012 | 06:19 AM
slowec's Avatar
80e !!
Old Apr 25, 2012 | 06:43 AM
2doorfury's Avatar
alot of people on here have had really good luck with RPM 60e. ive got one, but havent really got to use it since im still a work in progress. if this trans goes, 80e forsure.
