Another frikin pinion seal!???
Old Nov 18, 2006 | 04:18 PM
virgils4.85spd's Avatar
Default Another frikin pinion seal!???
Whats the deal here? I have about 30,000 mi maybe... on the current whole rearend. Eaton lsd 4.10 seals and bearings crush sleve, race all that. I changed all that out when my last rear end went bad when the guy i got to work on it didnt tighten the input shaft nut enough to hold it tight which messed up the gears. I did the last install and i know i tightened the hell out of that mother! Now i have slack in the bearings again and the pinion seal is leaking! Whats the prob? Anybody have these issues? I have the truck leveled, that wouldnt need pinion angle adjustment would it? Somebody help.
Thanks,
Derek
Old Nov 18, 2006 | 10:22 PM
Dirty Dave's Avatar
Did you put in a new crush sleeve?
Old Nov 18, 2006 | 11:05 PM
Grumpy5.3's Avatar
did you put teflon on the splines of the yolk??? it will leak from there also
Chavette
Oct 28, 2015 07:33 PM
Tigger Welder
Oct 1, 2015 08:41 AM
97_ek
Sep 23, 2015 09:16 PM
fctry286
Sep 5, 2015 11:48 AM
