american racing trakstar wheels
Old Sep 19, 2007 | 07:18 PM
912jonathon's Avatar
Default american racing trakstar wheels
i just found these as i was looking for some custom wheels that are wide enough for a 28x11x16 slick and i found these. looks like you can order custom backspacing. do you think the 16x9.5 with 6.0 backspacing would fit and not stick out past the finders
http://www.americanracing.com/browse_vintage.asp#
Old Sep 19, 2007 | 07:33 PM
tarinitup's Avatar
9 Second Truck Club
how much are they?
Old Sep 19, 2007 | 07:50 PM
tryin to find that now
here you go
http://www.customwheelsdirect.com/wh...l.php?id=36628
Old Sep 19, 2007 | 08:55 PM
BlackLM7's Avatar
What vehicle are they going on? They won't fit on your 2003 RCSB because the bolt pattern is only 5 lugs. Can you order a custom bolt pattern or something? Good looking wheel, no doubt. How much do they weigh?
Old Sep 20, 2007 | 04:34 AM
if they dont offer 6 lug il just convert to 5 lug.
Old Sep 20, 2007 | 08:00 AM
Raffman's Avatar
The problem with fitting 16"wheels with a lot of back spacing is sometimes the "drop center" of the wheel. That's the depression in the rim used to help install the tire. Most are in the center of the wheel to make it easy and it starts to hit the caliper when moved inward. Look at a factory steel wheel it's near the outside, thats why widening these should not interfere with the caliper, aftermarket is another story.
Old Sep 20, 2007 | 08:32 AM
well they also offer a 17x11 that should not be a problem with that. and looks like you can get them in 6 lug. im going to give them a call later.
thanks for the info
Old Sep 20, 2007 | 03:18 PM
02BlueStepside's Avatar
On a 9.5" wheel, 6" will stick out some, 6.5" tucks a little, almost flush.
Old Sep 20, 2007 | 05:23 PM
ok thanks for the info. you can order these in any backspacing you want, and any lug pattern.
Old Sep 20, 2007 | 05:30 PM
RandomHero's Avatar
why not just buy INTRO's then? $1450 for any choice of your rims
