aluminum driveshaft for Silverado?
Old Dec 17, 2006 | 05:11 PM
2001CamaroGuy's Avatar
Default aluminum driveshaft for Silverado?
My 04 Silverado (short bed/short cab) has the stock steel drive shaft. Did GM ever make an aluminum drive shaft that I could direct swap into my truck or would I need to have one built? If so, info please...
Old Dec 17, 2006 | 05:49 PM
Spires's Avatar
My 2001 Silverado 4x4 extended cab has an all aluminum driveshaft. It's amazingly light.
Old Dec 17, 2006 | 05:53 PM
hmm....but would that fit in my truck.....
Old Dec 17, 2006 | 06:16 PM
closet red neck's Avatar
Do you have the single cab, short bed?? If so then you can get one made from Denny's. I had one made for my truck. The cost is kinda steep but worth it for high speeds. Some people on here use the stocker but I had one made.
James
Old Dec 23, 2006 | 10:13 PM
James
yes, have a single cab/short bed. IS THERE a stocker that will direct swap?
Old Dec 24, 2006 | 02:49 PM
No, not to my knowledge.
James
Old Dec 24, 2006 | 04:29 PM
oh well...thanks
Old Dec 24, 2006 | 08:10 PM
thunder550's Avatar
High on diesel fumes
Too bad...I have the stock aluminum one from my 4x4 EC in my garage...you're local too....
Old Dec 24, 2006 | 09:22 PM
is it a one piece? I could probubly have it shortened pretty cheap
Old Dec 24, 2006 | 11:48 PM
454SuperSport's Avatar
i got a 01' rcsb and it has an aluminum driveshaft, i thought all of the were aluminum except for 99-00 trucks?
