Aluminum drive shaft
Old Nov 14, 2016 | 12:56 PM
DrX's Avatar
DrX
Originally Posted by stealthperf
A buddy of mine is running a twin turbo dmax. He's running the stock aluminum shaft. Last time out he ran an 11.27 @ 120 + mph.... I was just thinking of it will hold up to that, my 6.0 gasser shouldn't ever have a problem.
Your driveshaft will be spinning much faster than one on a diesel.
Old Nov 14, 2016 | 02:28 PM
stealthperf's Avatar
I'm sorry... I'm not getting it... Do the Diesels have like super high gears or something so the drivetrains turn slower?
Old Nov 14, 2016 | 02:40 PM
Okay, I see now that the transmission is geared higher in OD. There is however many crew cab gassers also... Just had one at my shop today.
Old Nov 14, 2016 | 08:32 PM
DrX's Avatar
DrX
Don't blame you.....
Actually it depends on the differential gear ratio. Same ratio, tire size and road speed = same driveshaft speed. Doesn't matter what engine/trans.
I had the Ram Cummins 3.42 axle ratio stuck in my head, with all OE axles being 3.42 only now. And that diesels can get by with a taller ratio. But both a gasser and a diesel could be equipped with the same gears and would therefore see the same axle speeds.
Old Nov 15, 2016 | 12:20 AM
LPCWS6's Avatar
I wouldn't put a factory one piece aluminium drive shaft in my truck. If you're dead set on a one piece I'd contact these guys Chevy Truck drive shaft* GMC truck drive shaft.
They built the 2 piece in my truck. They didn't even recommend a one piece in my ecsb 2wd 4l80e turbo truck.
Old Nov 15, 2016 | 09:07 AM
Yep, thanks! I talked to them yesterday... They said they could build one for me. They asked what max speed would be and I told them about 110. After doing the math, the max speed turned out to be 110. I would only drag race it once a summer (local event at an airport). I don't think I would run much any more than 110 in a quarter mile.
I know 110 probably seems slow but I use this for towing my bass boat so I don't want to go to crazy on it. And it is a ccsb 2500 so it weighs about 6500 pounds... It's kind of a lead sled.
This is my set up......
2004 Silverado 4x4 2500 ccsb
Tvs1900 8-10 psi
Ls9 cam with supporting parts
90mm throttle body
Araid intake
ARH 1 7/8 primary headers
4.56 gears
Lowered 4”
Smith Racecraft Assassin Bars
Rare parts tie rods
Dirty hooker diesel pitman arm brace
285/60 18 tires
Black bear tune
https://youtu.be/9g7AWemcGNo
