Air helper?
Hey. I want to ask you which is best to use stock height air helper or need to be slammed air helper since my truck on the rear been drop to 4" inch. I need ti know which one I should get. To support the tow I'm pull a boat and atv. Hope hear from you soon.
The second link is the one dezert1500 (sp?) has on his truck and its dropped 6/9 Right now my truck is 5/8 and I plan to get those...The Bag is slimmer so less stuff to rub on...I know after a certain point you have to move the top bracket up and probably weld it, But for 4" ..You should be ok...
I looked at slammed air lift that only allow go up to 1600 lbs which I need look for 2000-5000 lbs max anyone can help me out faster?
Look at my picture I just done lower my truck 2/4
1600 should be plenty..I think you confuse the weight of what your towing with the weight of tongue..
If you tow 5000 then the tongue weight should be around 500-750... so the 1600 bag will be fine..
This time. I want to see which one I should get it. Which one will work on my truck for 4" lower on back.
http://www.summitracing.com/parts/FIP-2320/
OR
http://www.summitracing.com/parts/AIR-59209/ (look like this one will be fit on mine)
But where I can find a cheaper air comp package with this air helper.
OR
Vortec350ss
Jan 12, 2016 10:36 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
