Air Bags....Can they Help Traction?
Old Nov 21, 2006 | 09:42 PM
Question Air Bags....Can they Help Traction?
I see that so many guys are having traction issues with their trucks.
I was wondering if adding the air bag helpers bags could increase traction?
I've seen it used on Mustangs. They place it on the right rear inside the spring.
I was curious if you installed the air bags and just pumped up the one on the right rear, would it help keep the right rear leaf spring from flexing and losing traction?
Just an idea I've seen used on Mustangs. I know we have trucks, but the basic concept is still there.
Jim
Old Nov 21, 2006 | 10:44 PM
negativeswitches's Avatar
it has been done and works to an extent, #1 problem is one installe dyou ahve to keep atleast like 40 psi of air in them which will raise you up a lil bit lil stiffer
best option still is to get some caltracs
Old Nov 22, 2006 | 04:55 PM
They actually only need a minimum of 10psi in them at all times. At least the Firestone ones.
I have the Caltracs, but I was looking for more added security of traction aid.
Jim
Old Nov 22, 2006 | 07:22 PM
depending on where you ride height in comparison to the bags when they are at odd psi i've seen the guys with s-10s and that setup tear bags up and anything less than 30 at all times
ya really cant hurt them unless they reach one or both of thier max/min heights or they rub from low pressure
10 psi shouldent make any diff in lift height
-Erik
Old Nov 22, 2006 | 08:48 PM
blue 01's Avatar
I run 7 in mine. They been on for 4 years. Next time I am at the track I am going to try 5 then 70 to see if I can tell a differance.
Old Nov 22, 2006 | 10:05 PM
You only want to pump up the right rear bag though.
Jim
Vortec350ss
Jan 12, 2016 10:36 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
turbo6c3
Oct 5, 2015 06:11 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
twake_410
Sep 25, 2015 10:09 PM
