Aftermarket Driveshaft questions
Old 11-03-2010, 08:23 PM
  #21
03sierraslt's Avatar
So what all factory setups come with 1350 Ujoints? Mine had them stock, I never realized it till I took the measurements on it when I ordered my new driveshaft. I was kinda shocked. On a side note Ill have my new driveshaft Friday.
Old 11-04-2010, 06:59 PM
  #22
Got my new driveshaft, just put it in. 5" looks huge once its installed but no clearance issues so i am happy so far. Ill post some pics in a bit
Old 11-04-2010, 08:09 PM
  #23
New is on the left.
The pics dont do it any justice, its very large compared to the stocker.
Old 11-04-2010, 08:28 PM
  #24
fastnblu's Avatar
Originally Posted by dewmanshu
...As you know, I am a ECSB 4wd, I am running a 3" steel, speed balanced. I need to speed balance it again. Probably should do every couple years. I swapped over to the 2 piece but came back to the one piece.
I thought once it's balanced, u just forget about it. Or only if u change gears, & it therefore changes critical?
... The pics dont do it any justice, its very large compared to the stocker.
That's what she said.
And the weight difference? You didn't forget, did u Pat?
Old 11-04-2010, 08:44 PM
  #25
Ummm, ****... Ill weigh the stocker, then Ill weight the packaging and subtract the weight of the packaging from the shipping weight ( 35lb) It has to be at least twice the weight.
Old 11-04-2010, 08:58 PM
  #26
scooter k's Avatar
Denny's wouldn't make you a shaft that long? or just not in aluminum?
Old 11-04-2010, 09:19 PM
  #27
They said i had two options, two piece that they could do or single alum that they couldnt do ( said they dont do alum that long). So i called driveshaft specialist ( same place Atomic got his)
Old 11-04-2010, 09:26 PM
  #28
scooter k's Avatar
Mine is that long too. I guess I will need to give them a call. What is the hp rating on your shaft?
Old 11-04-2010, 09:35 PM
  #29
I have a gauge for that
Atomic's Avatar
they said 800 on mine, 4" al with 1350s
Old 11-05-2010, 04:29 AM
  #30
11 sec. Truck Mod
TIM Z's Avatar
Thats a beefy looking piece there Pat. One less thing to worry about.
Im def. going to invest in one.
Are you still going to have room for drive shaft loops? I think you should just curious.
Quick Reply: Aftermarket Driveshaft questions
