additional trans cooling
Old Jun 26, 2006 | 12:57 PM
jus1975's Avatar
Default additional trans cooling
I purchased an additional trans cooler. How do you install between the rad. and transmission. Does it matter if it is between the input or the output of the rad.. I would think you would want it on the output side of the rad. I haven't looked at it yet but are the cooling lines hard lines or rubber. I looks as if they are hard lines.
Old Jun 26, 2006 | 07:21 PM
jus1975's Avatar
I know someone knows.
Old Jun 26, 2006 | 07:55 PM
RoninsDenali's Avatar
You want the fluid to flow to the radiator first, then to the additional cooler. Even with the water temperature about 160-180 degrees, the cooling capicity of water is lot higher than air. (water = 4.168 J/g°C, vs. Air = 1.005 J/g°C)
Besides, keeping it flowing through the radiator helps keep the transmission fluid warm during extremly cold weather.
Old Jun 26, 2006 | 08:18 PM
closet red neck's Avatar
Yes, they are hard lines(to the best of my knowledge,it's been awhile). Most that I've seen on here, people are putting them in front of the rad. Basically in the same place as the factory one. Tihs is where I put mine.
James
Old Jun 27, 2006 | 06:59 PM
I5M5's Avatar
Any special fittings to make one fit? Or will all the parts be included with the tranny cooler kit?
Old Jun 27, 2006 | 08:37 PM
Depends on how you go about installing, if you want a quick install and don't care much about looks then the rubber hose, barb fitting, and hose clamps will do just fine. If you are looking more for a factory look, or using SS braided hose then it will cost more.
Old Jun 28, 2006 | 10:46 PM
jus1975's Avatar
What kind of fittings will you need?
GRRR65GTO
Aug 17, 2015 11:33 PM
dantheman1540
Jul 29, 2015 04:45 PM
ferrellrooster
Jul 17, 2015 07:07 AM
