ADD A Leaf Question
Old Jul 5, 2007 | 08:45 PM
MonsterZ28's Avatar
Default ADD A Leaf Question
If i get the add a leaf's from pro comp/ skyjacker/ superlift it says 2.5 inch or 3 in, is that how much it lifts it?
If so what can i do to the front bumper so that its at equal height or about an inch lower than the back
Old Jul 5, 2007 | 08:46 PM
nightrunner's Avatar
Mr. Obvious
crank the tbars for some lift
Old Jul 5, 2007 | 09:01 PM
MonsterZ28's Avatar
already cranked
Old Jul 5, 2007 | 09:14 PM
Wide Open's Avatar
Originally Posted by MonsterZ28
already cranked
Buy a set of torsion bars with higher spring rates. That will get you more lift.
Old Jul 5, 2007 | 10:27 PM
StrokerAce03's Avatar
That's how wide the leaf is. It only gives about 1-1.5" of lift. If you're going with them in the back then go with some Ford keys in the front or some GK torsion bars. The GK bars are ones for the 1 tons and will give you about 1.5-2" of lift.
Old Jul 5, 2007 | 10:38 PM
MonsterZ28's Avatar
if theyre that wide will they fit on a 1/2 ton? If its only 1-1.5" i probably won't worry about it because i like the look of the slight rake
Old Jul 6, 2007 | 04:01 AM
dropkick13's Avatar
what about these
http://www.offroaddesign.com/catalog/Zero%20Rates.htm
Old Jul 6, 2007 | 10:06 AM
MonsterZ28's Avatar
those wont work, i'm actually looking to increase the payload and reduce the sag when i pull an 8000lb trailer
Old Jul 6, 2007 | 10:54 AM
MonsterZ28's Avatar
What about these?
http://store.summitracing.com/partde...5&autoview=sku
They add 3000lbs per set. I guess i would need an air compresser, whats a good brand. At least i can get a set of air horns now.
Old Jul 6, 2007 | 10:59 AM
Wide Open's Avatar
What about these?
I use a set like those. They work great.
The air compressors are listed on the Suggested Parts tab.
