accidently put in the wrong gear lube :(
You mean the square head plug on the bottom of the differential housing itself right?
Originally Posted by silver-mod-o
nope, identical cover to the 03 Z71 rear thats in the truck right now.... its a 2000 2wd BTW
BTW, mine does. But I haven't been able to use it with my new diff yet, I changed the fluid and the cover gasket after break-in without even realizing the plug was there. And then, the next time I had to change it, two weeks ago now, my diff cover gasket had a leak, so I couldn't use it again. At least I have a truck built BEFORE GM started cutting costs so much that a $5 drain plug was a serious issue.
