99-07 4WD Front Coilover Conversion
Old May 25, 2013 | 06:51 PM
  #21
mitchellmade's Avatar
MASS seller approved
I know I can use your upper bracket but I have drop control arms wondering what to do on the bottom
Old May 25, 2013 | 07:00 PM
  #22
Atomic's Avatar
I have a gauge for that
Post a pic of them if you dont mind.
Old May 25, 2013 | 07:09 PM
  #23
I believe they areon djm website if not I'll post one when I go to garage
Old May 25, 2013 | 08:52 PM
  #24
Atomic's Avatar
If it is one of these then I dont think my brackets will work: 99 – 06 4WD Silverado (not crew) Kits | DJM Suspension | DJM Suspension
however I would still like a pic of yours...not sure how close that shock mount is to the cv....you may have room to work with.
Old May 25, 2013 | 11:10 PM
  #25
Atomic's Avatar
I put the truck down on the coilovers for the first time with the engine and trans in it...it sits a little lower than I would like actually. Right now I have a 6" 1000lb spring with no preload. I plan on swapping my 7" 1000lb springs on and loading them about half an inch to put it back in the middle of the shocks range. If I need to I might have to go to some 1200lb springs, but the 1000s seemed like a good starting point. I can bottom them out jumping on the bumper which is why I need to raise the front some....or I could try that stud conversion mount I posted about...The rear is still on jack stands which makes the pic somewhat deceiving.
Old May 26, 2013 | 01:10 AM
  #26
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
ive done coils-control arms-drop spindles coils and controls arms ride like **** and the drop spindles made the truck handle like ****.
im def looking into doing coil overs
Old May 27, 2013 | 09:15 PM
  #27
2K Silvy's Avatar
Is that a good way to drop these trucks? How would geometry be after that. It would be cheaper and a better ride than all the other ways.
Old May 27, 2013 | 09:29 PM
  #28
Atomic's Avatar
Here she is fully loaded and sitting level
I ended up putting in the 7" spring and giving it about an inch of preload for it to sit level. I am right in the middle of the shock travel.
Old May 27, 2013 | 11:02 PM
  #29
nh1's Avatar
nh1
Registered User
what are your fender hieght measurements?
Old May 27, 2013 | 11:26 PM
  #30
Atomic's Avatar
32 in the front and 32.5 in the back...275/50/17 tires. 2in shackle in the rear, but my spring perches are higher so its maybe a 1" drop.
