99-07 4WD Front Coilover Conversion
Old Apr 3, 2014 | 05:54 PM
  #111
Atomic's Avatar
I have a gauge for that
Originally Posted by Richardman1992
By -3 to +3" do you mean lifting or lowering it to level with the back end? Cv angles still come into play when working with coilovers, correct?
From standard height, a 3" drop or 3" lift is doable with just coilovers. Yes, cv and steering angles still come into play. The front end geometry doesnt change; just how you gain/loose the height does.
Originally Posted by Akchev
Do you have a set left? If so how much to ship to 99709
Yes.
$180 shipped for a set of just lower or uppers, or $315 shipped for both.
Old Apr 4, 2014 | 07:07 AM
  #112
BigDaddy0381's Avatar
Great guy to buy from and knows his stuff. These brackets are build like a tank. I'm still gathering parts but should have a post on it fairly soon.
Old Apr 5, 2014 | 11:08 PM
  #113
Richardman1992's Avatar
What is the limit on lifting the front before wear is really increased on the front end components and cv's?
Old Apr 6, 2014 | 12:40 AM
  #114
Atomic's Avatar
No different with coilovers than normal cranking...couple inches, depending how hard you drive it.
Old Apr 7, 2014 | 08:26 AM
  #115
Vortec350ss's Avatar
I haven't seen anything talking specifically to the cost of this from a-z.
Anyone have a guess? I love the idea of doing this. Also, does it seem that limiting straps are unnecessary for the track after this swap?
Old Apr 7, 2014 | 08:28 AM
  #116
Atomic's Avatar
I dont use straps and have not had any problems with shocking the tire.
Total cost is roughly 700-800 depending on what exact parts you use. The most expensive item is the shocks.
Old Apr 7, 2014 | 09:26 AM
  #117
This has me seriously thinking. It would also make my life a lot easier with the dual 3 into 4" exhaust system... I'm sure you love the added space with the exhaust you're running.
Old Apr 7, 2014 | 09:39 AM
  #118
Atomic's Avatar
Oh yea, clears up a lot of room under there. It was nice having the tbar crossmember to support the tcase when im taking stuff apart, but its a small price to pay. I may make a small crossmember for just that purpose at some point. Still have the factory crossmember in the corner of the garage, but I use the torsion bars as workout equipment now
Old Apr 7, 2014 | 09:50 AM
  #119
so since I have your attention... what parts combo do you recommend? If I'm going to pursue this I want to have a clear understanding of what would be best for me.
Old Apr 7, 2014 | 09:58 AM
  #120
Atomic's Avatar
It depends on your ride height, which is why I ask every one to measure before I recommend parts.
But in my case, I have my cvs perfectly level, which means a 1-2" drop, I have
qa1 ds301 shocks
procomp shock adapters
upgraded steel bearings
hyperco 1300lb springs
generic bumpstops
little spacers for the bolts
qa1 washer/spanner wrench
