99-06 lowered pics on 20s.
Old Jan 23, 2018 | 02:00 PM
  #41
terravast4's Avatar
Originally Posted by ILuvJDM
That gray truck was 15.5" hub to fender in front. Red truck should be 15.0" hub to fender. Gray truck was 2wd but with torsion bars, red truck is traditional coil spring 2wd. So completely different setups so to speak, but roughly the same ride height - if that makes any sense lol
Yes. Im interested in knowing all the front suspension parts on the red truck. What are the lower control arms you used? What coilivers and ratings dud yiu use. Any infirmation will help. I want that same drop up front
Old Jan 23, 2018 | 02:16 PM
  #42
ILuvJDM's Avatar
well, the parts I've bought might not work for my drop, so I will have to update whenever I am able to see if they work. The shocks I bought use a 9" spring, but that spring selection is extremely limited. I bought a 10" spring but I'm not sure if it will be able to get low enough
Old Jan 23, 2018 | 07:24 PM
  #43
ILuvJDM's Avatar
I was able to test fit the springs and it seems to work fine. The springs are at the lowest setting possible, which is too low. I measure 14.25" hub to fender and it's actually tucking tire. So I will raise it up slightly, but it's good to know they fit.
VAS lower control arms
Belltech 2" spindles
Stock UCAs that have the balljoints flipped and Belltech offset bushings installed
Viking c205 shocks with 10" 850lb/in coilover springs
Old Jan 23, 2018 | 07:56 PM
  #44
haulin-c10's Avatar
Originally Posted by BlueTexan24
20x10 wheels 305/50/20 tires with a 2" drop in the back
How was you to get that much drop on those wheels?
Old Jan 23, 2018 | 07:57 PM
  #45
haulin-c10's Avatar
is this the same drop as your red truck?
Do you have problems with speed bumps or rubbing?
Old Mar 19, 2018 | 09:19 PM
  #46
hlpressley's Avatar
4/6 with 275/45/20
Nice truck! Perfect stance IMO
Old Mar 20, 2018 | 12:25 AM
  #47
CCrowell2's Avatar
3 1/2" and 5" out back on 17s
Old Jan 28, 2019 | 11:02 PM
  #48
matslp488's Avatar
4-6 on 275 45 20s
Old May 27, 2019 | 09:18 PM
  #49
hlpressley's Avatar
Bumping this back up as I am interested as well. Post em up!
Old May 30, 2019 | 12:03 PM
  #50
Reckless's Avatar
Still moddin'
Have 22's on there now.........
This is a rendering of the new setup coming with 20x14 rears
