96' LS Swap
Old Dec 28, 2015 | 09:09 AM
thecaminokid's Avatar
Default 96' LS Swap
I have a 1996 OBS Silverado and am planning on doing an LS swap and was wondering if the transmission and torque converter I currently have in the truck will work. It is a one piece bellhousing 4L60e. Any help would be greatly appreciated.
Old Dec 29, 2015 | 06:55 PM
UnVmy5.3's Avatar
yes it will, you have to enlarge the holes on the flex plate and use a crank spacer
Old Dec 30, 2015 | 11:32 AM
Thanks!
After doing some digging it looks like I will need a flat flywheel, the one I have is curved.
Old Dec 30, 2015 | 03:35 PM
UnVmy5.3's Avatar
you can use the curved one.. I have a swapped 98 and a swapped 93 c1500.....
Old Dec 30, 2015 | 03:45 PM
tgui's Avatar
Curved? Like the one on the bottom of my pic. Thats from my stock 4l60e. The top is flat and replaces the curved. 02 Yukon btw.
Old Dec 30, 2015 | 04:50 PM
I thought I read the curved wouldn't work for some reason. What adapter kit did you use?
Yup, like the bottom one.
Old Dec 30, 2015 | 05:00 PM
tgui's Avatar
Since you're doing an ls swap, the TCI I showed would probably work for you without an adapter. Its specifically for 4l60e to ls style motors. Mr. GMC beat into my head to just get rid of the factory crap if you plan to make any power. During a swap is when to do it!
Old Dec 30, 2015 | 06:00 PM
The plan is to get everything running correctly and then turbo it, when the turbo goes on I'm going to switch to a 4L80e.
Old Dec 30, 2015 | 08:12 PM
Ok, I found this. It looks like, seeing as I have a short crank and early trans, I use the adapter plate between the flywheel and converter as seen in note 3.
Old Dec 30, 2015 | 08:43 PM
tgui's Avatar
I might have the adapter you need. I thought I needed it and didn't. I'll give you a great price if you give it a good home.
