911 need answer FAST about Trans
Old Dec 22, 2007 | 06:31 PM
trxmxzx's Avatar
13 Second Truck Club
Default 911 need answer FAST about Trans
Installing a 2000 sierra FLT4 trans in a 04 Avalanche 1500 (both 4wd)
I came across 2 different wiring harnesses for this trans betwwen these years, will I run into a issue?
now theres a noise!!!!
Old Dec 22, 2007 | 07:27 PM
trxmxzx's Avatar
bump need help
Old Dec 22, 2007 | 07:54 PM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
if they are both 4l60e/65e you should run into no problems
Old Dec 22, 2007 | 08:45 PM
trxmxzx's Avatar
awesome thank you!
Old Dec 22, 2007 | 09:39 PM
trxmxzx's Avatar
well we have a noise! little tick noise when its in reverse. it did it when we started it, it was low on trans fluid and now it just does it in reverse. wondering WTF it could be Im hoping its not the trans pump being pinched or of some type..
when we put the trans in I noticed the dowl wasnt in the motor on the driver side, so i had my buddy put it in when the trans was loose and he could only get it in so far, theres about a 1/4 gap in the hole on the trans side... meaning its in pretty far, just it was the only problem we ran into, and thought we could solve it when the trans was installed hoping that it wouldnt be a problem
could this be a my probelm?.
Old Dec 23, 2007 | 09:38 AM
Gap is bad and likley the noise is a result of it you need to get that fixed ,
Old Dec 23, 2007 | 11:09 AM
trxmxzx's Avatar
theres no gap between the engine and trans all i was trying to explain was that we could only get that dowl (alingment pin) in so far. I was wondering if that was the issue or not
new torque converter, wonder if my buddy didnt pore enough oil in it before he put it in maybe thats what was the issue
we ran in down the road and it shifts great goes through all the gears, it dont make that noise anymore...... weird.....
un hope theres not a issue
thanks 4 your time
echoman
Aug 22, 2015 01:53 PM
1bad2k
Aug 18, 2015 09:50 PM
Hmguyton
Aug 9, 2015 05:38 PM
Deceptarado
Jul 8, 2015 05:24 PM
