8spd auto
Old Dec 30, 2005 | 12:08 AM
moregrip's Avatar
what a rush!
Default 8spd auto
http://www.detnews.com/2005/autosins...uto-286278.htm
http://appft1.uspto.gov/netacgi/nph-...RS=20050113206
http://www.freepatentsonline.com/6976931.pdf
Old Dec 30, 2005 | 12:11 AM
moregrip's Avatar
what a rush!
http://www.freepatentsonline.com/20050282679.pdf
Old Dec 30, 2005 | 12:13 AM
thunder550's Avatar
High on diesel fumes
"General Motors Corp. _ racing to catch up in the gear wars _ is working with Ford on a new, jointly designed six-speed transmission that will start appearing in GM vehicles in 2006. "
I thought CVT was the next big leap in trannies....why does it seem like work has stalled on it?
Old Dec 30, 2005 | 12:15 AM
thunder550's Avatar
"Mr. Stephens is also skeptical of continuously variable transmissions, which use belts and pulleys instead of gears."
I guess that explains it....
Old Dec 30, 2005 | 12:16 AM
moregrip's Avatar
what a rush!
http://www.zeroshift.com/about/press.htm
Old Dec 30, 2005 | 12:28 AM
stone150's Avatar
my mom's murano has cvt in it nice a smoth but robs power, don't like it!
Old Dec 30, 2005 | 12:01 PM
04BlackGmc's Avatar
10 Second Club
My mom has one too, burnt copper with the matching leather interior.
Old Dec 30, 2005 | 12:25 PM
vanillagorilla's Avatar
That guy needs to pull his head out of his ***. The CVT we played with, that a fellow student designed had no belts or pulleys. It wasn't even wholely oringinal either. It was based off existing designs that have been out there for awhile. That guy's a tool.
Old Dec 30, 2005 | 12:38 PM
Why don't they just take a 4spd auto, and add an under/overdrive unit to it. Program the damned thing so it can gear split. Wallah, you have an 8spd auto. You'd even have two reverse gears too. WOW! My 4spd auto was crap and I imagine an 8spd auto would be twice as crappy. 3 planetaries and a ****-ton more clutch packs is a lot more to go wrong IMO. It probably weighs a metric ton too. Any mileage benifits it creates it probably sacrifices due to weight and all the power it'll rob. It's sad when we live in a world that can put men on the moon, magically insert syrup into bread, and create mind altering drugs, but we can't create a decent production automatic transmission. If its strong, then the gear ratios suck, if the gear ratios are decent, then its weak. If the gear ratios rock then it doesn't bolt to your engine. Ahhh....I'll stop now.
CVT's are the future, pass it on.
Old Dec 31, 2005 | 12:58 AM
moregrip's Avatar
what a rush!
I saw some patents for the CVT as well, so that may still be a go
SloSVO
Nov 22, 2020 07:34 PM
dsbodley
Nov 14, 2015 09:46 PM
Rockrz
Sep 29, 2015 09:07 AM
dantheman1540
14
Sep 28, 2015 09:22 PM
Closer_2001
Sep 24, 2015 09:15 PM
