80e tcase options and drivelines?
Old Jun 18, 2014 | 08:10 AM
lsxperformance's Avatar
Default 80e tcase options and drivelines?
I'm doin an 80e swap and am gonna use a 4x4 tcase from a 3/4 ton that has the manual shift lever so I can lock into mustang killer mode. My question is they did this in 3/4 ton trucks from factory I should be able to get t case and front driveshaft from a yard. Does any one know the specific t case number I'm after so I know what I'm after? Also will the d max shafts work as well. Should I get the rear shaft as well and have it shortened then have one made.
My truck is a Sierra Denali 1/2 ton crew maybe someone knows.
Thanks guys.
Old Jun 18, 2014 | 09:19 AM
Np2? That the tcase I'm after is there a difference on HD trucks they were askin if it was HD..
Old Jun 18, 2014 | 11:31 AM
Vortec350ss's Avatar
I think youo may be looking for an NP1... whats the difference between than and the NP2. Does the NP2 give you an 'AWD' auto 4wd option?
Old Jun 18, 2014 | 04:13 PM
It's just has a hi/low 4x4 and is done via a lever
Old Jun 18, 2014 | 04:15 PM
Oh you want floor shift? I assumed you were going for the electronic TC.
Old Jun 18, 2014 | 05:05 PM
Na even more basic just gonna slide in and lock it in when I wanna play
Old Jun 18, 2014 | 05:11 PM
thunder550's Avatar
High on diesel fumes
I think you'll want to look for something from a 2500 6.0 gas truck that had a 4L80E. The diesel trucks either had the 5 speed Allison automatic or the 6 speed manual ZF6 trans, and I'm not sure if those had the same bolt patterns or output shaft sizes.
Looking at car-part.com I'm seeing NP2 and NVG261 as the model number for the floor shift, but that same model is listed under the 5 speed auto, 6 speed manual, and 4 speed auto trans. Not sure what the differences are.
According to this site the HD trucks have a larger slip yoke, that might be why your source is asking. http://www.justchevytrucks.com/parts...sfercases.html
Old Jun 18, 2014 | 05:16 PM
timmay208's Avatar
NP261HD is a floor shifter, 6.0 used that
Old Jun 18, 2014 | 05:17 PM
I'm willing to bet GM kept the output shafts similar and the transfer case adapter will all have the same bolt pattern for the TC's.
Old Jun 18, 2014 | 05:26 PM
Thanks guys, I wonder if there would be benefit to larger shafts of the HD? Smaller shaft in 1350 series be plenty hmm tough one. I just don't wanna get the wrong one and be screwed later lol.
SloSVO
Nov 22, 2020 07:34 PM
thompson
Dec 27, 2017 06:48 AM
Wrecker 426
Sep 30, 2015 09:39 PM
Closer_2001
Sep 24, 2015 09:15 PM
iregret
Sep 7, 2015 01:20 PM
