80e swap... Got a few questions.
Old May 27, 2014 | 05:42 PM
  #21
Chevy_King1500's Avatar
I would rather be home chillin in the pool. It's 85 and humid as hell, the shop fan can only blow so hard
Old May 27, 2014 | 05:55 PM
  #22
oakley6575's Avatar
When do you hope to be driving this truck again? Your going to love the 80e
Old May 27, 2014 | 07:34 PM
  #23
03sierraslt's Avatar
I second that, I still love the way the 80e shifts. It's so crisp and precise, at least that's how I describe it. Granted I never had a stock one.
Old May 27, 2014 | 07:43 PM
  #24
Next week sometime, got a few parts ordered and I'll be out of town Friday-Sunday. so no working on the truck
Old Jun 2, 2014 | 09:31 PM
  #25
Update.
got the new slip yoke installed and drive shafts put back in.
exhaust is back on
dipstick tube is in (that was a PITA)
Things left to do..
shift cable braket (still in the mail)
fill trans with fluid
load new tune
Old Jun 2, 2014 | 10:28 PM
  #26
oakley6575's Avatar
The worst part of putting a fresh trans in is filling it with fluid. The 4L80e takes like 16 qts or some crap.
Old Jun 4, 2014 | 09:36 PM
  #27
finished up the swap tonight!
put 12 quarts of fluid in and it moves the truck good, it doesn't feel low or the converter too loose..
I forgot about switching the wires at the pcm, so that took a while to do.
put about 20 miles on it tonight. my tune got all kinds of screwed up when HP did the segment swap. Boost enrichment wasn't even active. so i made a quick pull at 10psi 13.00 afr
I couldn't get the converter to lock up on its own. When i commanded it with the scanner it worked fine. any thoughts
Old Jun 4, 2014 | 10:32 PM
  #28
oakley6575's Avatar
It won't lock at all on its own or it unlocks when you let off the throttle?
Old Jun 5, 2014 | 08:17 AM
  #29
it never locked up own its own.
trans temp was around 170*
i only got it up to about 55mph, but it should be locking in around 45.
Im gonna get the fluid level correct and i will report back
Old Jul 18, 2014 | 10:43 PM
  #30
well I got the fluid level up and took it on a 60 mile trip. I locked up the converter with the scanner about 10-15 different times. took the truck out the next day and the TC started working like normal
