80e Slector ?
Old Apr 10, 2006 | 08:00 PM
seeyaa's Avatar
Default 80e Slector ?
Just looking at the 80e i just bought and notice the gear slector is way differnt than my 60e and the wiring harness i got from speedE. dose not have anything to plug into the 80e slector. So how do you 80e swap guys do this.Pics would be great.
Old Apr 10, 2006 | 08:08 PM
Wilde Racing's Avatar
How do I change this text
I used the sellector off the 4l60e
Old Apr 10, 2006 | 08:14 PM
seeyaa's Avatar
sweeet i broke my 60e slector when pulled it. Hey you wouldn't have any good pics of your trans in the truck would you.also did you do all the work your self
Old Apr 10, 2006 | 08:49 PM
BigBlackAv's Avatar
yep...the selector off of the 4l60e bolts right back up...i'll try to find my pics and post in the am.
good luck
Old Apr 11, 2006 | 01:22 AM
James B.'s Avatar
This could be a problem if it is an early-model case. Are both fluid lines in the front? 1996 and earlier are like this.
Old Apr 11, 2006 | 06:02 AM
I'm not sure if this (pic) is the problem you are talking about, but this is one that I know of.
The earlier Trannys did not use a selector like the NBS, and they don't have the mounting bosses for the bolts to hold the selector.
I don't have any great photos, but I can go take a few, what part of the trans do you what a photo of?
And yes I did all the work my-self exept installing my rear window lol.
Old Apr 11, 2006 | 06:51 PM
seeyaa's Avatar
well the trans i have is a 05 so i went to the dealer picked up the 60e selector and it fits perfect.my new problems are the steelbrided lines how do these hook up to the trans i know it sounds dumb but the fittings do not hook to the trans or the truck.and 2nd, the tci flywheel dont bolt to the stock 80e converter but it bolts to my 3000 tci for the 60e. I will see if it fits the fuddle when i get it. and 3rd what do i do with the drive shafts how short how long.
sorry for all the ?
Old Apr 11, 2006 | 07:27 PM
BigBlackAv's Avatar
1...cut the hard lines w/ a tubing cutter and the fittings should fit on the steel lines (the fittings i had needed to have a flare put into the steel lines) and to the braided lines.
2...was the flywheel for a 6.0L? .. mine was and bolted up to my 'verter just fine
3...you should be able to take in the old ones to a shop and ask them to make the front one 1.5" longer and the rear 1.5" shorter.
Good luck!
Old Apr 11, 2006 | 07:37 PM
seeyaa's Avatar
ok if i cut the steel lines flare them them how do they go in the trans because none of the fittings fit in the trans.
Old Apr 11, 2006 | 07:41 PM
BigBlackAv's Avatar
oh...you can either get the fittings (oddly enough, when looking for other parts, i've seen them for sale at pepboys) or relocate them from the other tranny...I have seen other post what thread that is and get an AN fitting to fit the braided hose to the tranny (I would make it a 90* fitting)...but the 1st option seams the best and quickest...but be sure you have 4 of the steel to braided fittings (2 for each line).
good luck
