80e no 4th converter locking in 3rd
Old Jun 7, 2014 | 06:09 PM
LOWnEASY's Avatar
Default 80e no 4th converter locking in 3rd
Title says it all. My 4l80 isn't hitting 4th and my converter is locking in 3rd.
It's a 80e transgo hd2 circle d 3200 and its at 3000 rpm at 75 locked with 3.42 gears. It should be down around 23-2400 from what I gather off online calculators. Any idea what could be going on in there?
Old Jun 7, 2014 | 07:37 PM
Chevy_King1500's Avatar
having some of the same problems. converter will lock if I keep the shifter in "3"
mine shifts into 4th then around 55-60 it will tries to lock up then it kicks out
Old Jun 7, 2014 | 08:04 PM
LOWnEASY's Avatar
I from a manual and wonder if my tps needs adjusted, even though the motor was from a auto vehicle.
Old Jun 7, 2014 | 08:10 PM
does it shift in to 4th gear at all.
Old Jun 7, 2014 | 08:42 PM
LOWnEASY's Avatar
Doesn't even try. Just gets up to 28-3000 rpm around 75 and the converter locks. The convert actually locks wile cruising ~50-55 and holds about 23-2400 rpm and I'm sertan its locki g cause I can roll into the gas and at ~50% throttle it shoots up to 3000 rpm and holds till the speed matches the rpms and then rpm starts to climb with more speed
Old Jun 8, 2014 | 01:04 PM
LOWnEASY's Avatar
Any one ha e any idea what mite be causing this?
Old Jun 8, 2014 | 01:16 PM
James B.'s Avatar
Maybe the neutral safety switch on the side is clocked slightly off and the PCM thinks it's in "3" when actually in drive.
Old Jun 8, 2014 | 02:21 PM
LOWnEASY's Avatar
Didn't even think about that!!! Going to see about it now.
I even modified an early unit to take a nss with a home made bracket so it problem isn't set right.
Old Jun 8, 2014 | 04:13 PM
LOWnEASY's Avatar
Its clocked all the way to the park position were I think it should be and didn't change any thing.
Any other recommendations?
ferrellrooster
Mar 6, 2025 03:22 PM
Oobray
Jun 13, 2022 03:38 AM
Corvette454l88
Sep 1, 2016 01:24 AM
GMCtrk
Jul 17, 2015 06:39 PM
JordanH
Jul 14, 2015 03:46 PM
