80e conversion Whats needed
Old Sep 3, 2007 | 10:57 AM
Breeze's Avatar
11 Second Truck Club
Default 80e conversion Whats needed
Just checking what all I need for the 80e install. Please let me know if I am missing anything or if I dont need something I have listed thanks in advance.
Flex plate
converter
cover sheild
crankspacer
cross member
trans mount
wiring harnes
shifter cable bracket
lines fittings
dip stick & tube
yoke
Old Sep 3, 2007 | 01:32 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
shifter cable (maybe... I needed, but changed to 2wd too)
drive shaft sized (assuming you meant that with the yoke)
Old Sep 3, 2007 | 01:48 PM
Breeze's Avatar
yeah I got the shifter cable bracket there not detailed enough. (Ill edit that)
Im not sure about the cable either.
I guess the yoke is differentfrom the 60e to the 80e and also need the drive shaft resized but will probably will get a HD drive shaft while im at it.
Old Sep 3, 2007 | 01:51 PM
Derek @ EDO's Avatar
FormerVendor
If your interested,I think yank can build an 80e converter with the ls 3 bolt hole pattern so no crank spacer or flexplate is needed.
Old Sep 3, 2007 | 01:59 PM
ZR1 DREAMING's Avatar
Old Sep 3, 2007 | 03:26 PM
Breeze's Avatar
Originally Posted by Z06 DREAMING
Yep the 60e is on its way out.
Old Sep 3, 2007 | 04:58 PM
yeah, I got one more I'mgoing to throw in before I do the 80E convo.
Old Sep 3, 2007 | 05:54 PM
XLR8NSS's Avatar
Adkoonerstrator
Hey Bryan
What does your crossmember look like? If it was like the one in my old truck all you have to do is cut the mount off, flip it around, re-weld it and elongate the hole a bit. I'll look for that picture in a bit.
Also, I don't think you need the actual shifter cable, just the new bracket because the mount holes on the 80E are different IIRC.
Old Sep 3, 2007 | 06:00 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I used the bracket that came on my 80e for the shifter cable.
Old Sep 3, 2007 | 06:11 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
https://www.performancetrucks.net/fo...ight=dmc_racer
