80e and Borg Warner Transfer case...anyone done it?
Old Mar 3, 2016 | 08:35 AM
About20ninj45's Avatar
Originally Posted by 2002_Z28_Six_Speed
The BW4482 requires electric shifting unless you lock it into AWDhi and leave it. Would need a cover plate for the shifter hole. If it ever popped out of gear going down the road you would be screwed though.
I am not sure how much effort it is to add electric shifting to an AWD vehicle. You would need the shift motor and the button and harness.
I don't have the 4482, I have the 4481 in my denali
Old Mar 3, 2016 | 09:10 AM
03SuperSLADE's Avatar
Originally Posted by About20ninj45
You sir, are the man lol. Do you currently have this setup in your escalade? How are the awd launches with the 4l80, or do you have the 6l80?
Yes i am still running the 4L80e with the mod' d BW4481 and i probably shouldn't say this because it will probably break the next time i drive it but the drive train has not have any issues once i got the tranny built correct and I'm putting close to 700 to the wheels.
As for the launch, its pretty cool...
Old Mar 3, 2016 | 10:02 AM
DAMMMNNN thats awesome!! you sir have really peaked my interest. i gotta ask , why the ls3 harness e38/t42 controller?
Old Mar 3, 2016 | 10:44 AM
I lost the motor due to a failed lifter and the shop that was doing the tuning at the time suggested that while i have it apart i might want to consider switching to a 58X reluctor and 4x cam sensor and running a LS3 ECM. That the newer ECM would allow for better tuning capabilities. I really think he just liked working with LS3's more but mostly he saw $$$$, I took the bait.
I have to say it is definitely running smoother and stronger than it ever did with the stock computer but that could just be that i am spending 100's of hours tuning it myself as i learn more.
Old Mar 3, 2016 | 10:55 AM
lost the 6.0? Did you turn your 6.0 into the 408? I got a quote from livernois motorsports for turning my 6.0 into a 408 for 3800 if i use my own block... wonder if that to high..
Old Mar 3, 2016 | 11:12 AM
The factory 6.0 was lost to a spun bearing in 2010, when i bought the truck new i had the dealership put a centrifugal supercharger kit on it. I ran it hard for 10 years.
The lifter was lost on a Texas Speed 408, they mismatched a melling high volume oil pump and double roller timing chain. The chain was cutting into the oil pump from day one and took two years to fail.
Texas Speed was awesome and refreshed the motor for me at no charge.
Old Jul 19, 2017 | 03:45 PM
Guitageorge's Avatar
Hey 03 Superslade do you know if you could of used a Bw4485 instead of modding your bw4481 ??? I have a Turboed 04 Gmc Yukon Denali that I'm tired of putting built 4l65e in that don't last a month . I was estatic when I seen this thread but then priced out everything and realized I can buy a refurbished Bw4485 for less than a few of its parts ...Just don't know whats different about it ?
Old Mar 7, 2018 | 05:56 PM
Dustin Chesshir's Avatar
Registered User
Originally Posted by 03SuperSLADE
I just went back and looked, it was the BW 4485 that were in 2007 - 2011 Escalade's.
And these are the parts I ordered to do it.
GM Part # Description
19132803 SHAFT,TRFER CASE INPUT
19167564 Sprocket
19151772 Chain
88984540 Sprocket
88984518 Washer
15654927 Adapter
I have a 44-81 BorgWarner as well I was wondering do I have to change all those parts to get 32 splines or can I just change the input shaft are they the same on the back half needing information thank you I'm trying to build an all wheel drive 4 L 80
Old Oct 19, 2018 | 11:22 AM
tippmann243's Avatar
wondering this as well. Its a lot cheaper to get just the input shaft, vs all the parts or even a junkyard 4485.
Old Oct 19, 2018 | 02:20 PM
It was so long ago but from what i recall you should be able to just change the shaft. Sorry i cant say with 100% certainty.
