80 swap question
Old Jan 23, 2016 | 06:23 PM
GM-only's Avatar
Default 80 swap question
did my 80 swap today. well most of it. the truck is an 05. had a 4l60. i bought the nelson conversion harness, and the main portion is stupid easy. well i plugged the trucks speed sensor into the rearmost one on the 4l80 and when i went to plug the other one in i realized that it had three pins. my swap harness came with a two pin connector. can i just take the sensor out of the 60 and use it instead?
Old Jan 23, 2016 | 10:57 PM
03sierraslt's Avatar
The 80e sensor has three pins? Is that what your saying?
Old Jan 23, 2016 | 11:05 PM
GM-only's Avatar
yep. the sensor in the 80 is three pin. can i switch in the sensor from the 60? ive been reading as much as i can. havent found that answer yet. funny thing is that its usually your posts
Old Jan 23, 2016 | 11:28 PM
Never seen one with three pin, what year is it out of?
Old Jan 24, 2016 | 12:16 AM
EmmerichLSx's Avatar
formerly Emmerich 5.3 (2013-11-30)
If the connector will plug into the 60e sensor it will probably work. Maybe jump on o'rielly auto parts web site and see if the 60e and 80e speed sensor part numbers match up.
Old Jan 24, 2016 | 08:23 AM
GM-only's Avatar
hey thats a good idea.
im not really sure what year it is. it has the separated cooling lines. i believe that would be 97+ not sure what year specifically though
Old Jan 24, 2016 | 08:27 AM
GM-only's Avatar
they do seem to be the same part number. i think i may try it. i still have to get my yoke and shorten my driveshaft before ill know if it works.
Old Jan 24, 2016 | 10:09 AM
Can you post a picture of it?
Old Jan 24, 2016 | 02:21 PM
GM-only's Avatar
May have to zoom in to see it.
N
Old Jan 24, 2016 | 07:54 PM
Beatdown Z's Avatar
Laid Back
It looks like two pins to me. Have you tried plugging the connector into the speed sensor?
