70mph @ 3500rpms??
Old Feb 29, 2008 | 06:15 PM
beastmode's Avatar
Import Moderator
Default 70mph @ 3500rpms??
So i finally got a chance to take the Sierra out to the garage where im gonna be pullin the motor (which is about an hour away) and on my way out there the truck was ****** screamin. Granted I do have a 4000 stall speed ive never seen it that bad, it almost felt like it wasnt shifting into overdrive. Recetly i posted that i was getting a code that my syncro was stuck due to the stall speed beings o high... which ive determined the code just needs deleted and never did it cause the Sierras been parked. Anyways do you guys think this is a result of that code or is it just the converter and i never noticed it before???
im running
factory 3.73s
SS4000 converter
255/60/17 = 29.04" diameter
built 4L65E
Old Feb 29, 2008 | 06:18 PM
nightrunner's Avatar
Mr. Obvious
sounds like the converter might not be locking
Old Feb 29, 2008 | 06:47 PM
99Silverado5.3's Avatar
I agree...converter not locking up.
Old Feb 29, 2008 | 06:50 PM
TouchOfEvil04's Avatar
def. the converter not locking up man.
Old Feb 29, 2008 | 06:52 PM
dirt track racer 81's Avatar
how long did ya drive it..when its damn cold outside sometimes i gotta drive mine 6-8 miles before it will lock..my 40,000 gvw cooler dont help that
Old Feb 29, 2008 | 06:55 PM
03sierraslt's Avatar
Hell it doesnt even sound like it went into overdrive.
Old Feb 29, 2008 | 07:28 PM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
I would say the converter didnt lock up. I see your in PA and its definatly cold here, You do know the engine temp must get above 140 degees before the PCM will allow lockup?
Old Feb 29, 2008 | 07:31 PM
BlackGMC's Avatar
Resident Retard
Really? That is a good thing to know! No wonder my MPG sucks most of the time, but truck is barely warmed up by the time I get to work (I only live 5 miles from work).....
Old Feb 29, 2008 | 08:39 PM
Truckshop's Avatar
3500 rpm is in 3rd gear.
Old Feb 29, 2008 | 09:23 PM
KevinF56's Avatar
yeah i think it's not shifting into OD. even with a 4K converter i don't think it'd be that high in rpms at 70mph if it's just an unlocked converter.
