700R4 knocking while in reverse
Old Jan 14, 2006 | 10:44 PM
YenkoST's Avatar
Default 700R4 knocking while in reverse
Well like the title says...it just started knocking about a week ago while being in reverse. It is almost like a grinding/knocking(mixture of the two) noise coming from the front of the tranny or back of the engine, somewhere in that position from the cab...haven't gotten underneath it yet to see what's up. The tranny doesn't do this while in its forward gears though. Its weird b/c its never done that until a week ago and I am not hard on it at all. Any input would be great guys/gals!! Thanks!!
Old Jan 14, 2006 | 11:05 PM
Rhino79's Avatar
9 Second Club
Check for a cracked bellhousing/case, converter bolts, possibly cracked flywheel, or maybe the torque converter.
Old Jan 14, 2006 | 11:28 PM
YenkoST's Avatar
I would think the flywheel would knock in drive as well but I could be wrong...I will get underneath there tomm and check the bellhousing/case.
When you say torque converter....what do you mean...like its going out/failing or what?
Old Jan 15, 2006 | 01:53 AM
Rhino79's Avatar
9 Second Club
I mean that the torque converter may be failing.....I don't know but just something else to check is all else is good.
Old Jan 15, 2006 | 10:55 PM
YenkoST's Avatar
Ok....checked the motor mounts...look good.....checked bolt and bellhousing...looks fine...repositioned the 3 bolt header flange....priceless....no more knocking now!! Did find out that my rear main seal is leaking though!! Oh well....thanks for the help.
Blwn99x
Mar 24, 2023 11:14 AM
SloSVO
Nov 22, 2020 07:34 PM
Pimpinpete
43
Dec 22, 2017 08:13 AM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
trevorh1
Sep 27, 2015 08:47 PM
