700R4 knocking while in reverse
Well like the title says...it just started knocking about a week ago while being in reverse. It is almost like a grinding/knocking(mixture of the two) noise coming from the front of the tranny or back of the engine, somewhere in that position from the cab...haven't gotten underneath it yet to see what's up. The tranny doesn't do this while in its forward gears though. Its weird b/c its never done that until a week ago and I am not hard on it at all. Any input would be great guys/gals!! Thanks!!
I would think the flywheel would knock in drive as well but I could be wrong...I will get underneath there tomm and check the bellhousing/case.
When you say torque converter....what do you mean...like its going out/failing or what?
Ok....checked the motor mounts...look good.....checked bolt and bellhousing...looks fine...repositioned the 3 bolt header flange....priceless....no more knocking now!! Did find out that my rear main seal is leaking though!! Oh well....thanks for the help.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
