700r4 guru's need some info
Old Jul 24, 2014 | 04:00 PM
stroker87's Avatar
Default 700r4 guru's need some info
the tail shaft on my 700r4 cracked in two when i was making a pass but the drive shaft never came off or any thing....
I picked up a used 700r4 to take what I need off it and put mine back together worked out well and was much cheaper then buying the replacement parts ($75 of Craigslist)
well got it all together and its driving and shifting but its not the same?
1st gear at WOT would shift at 6200 rpm and I would shift 2nd and 3rd around 6000 rpm's, normal driving it would shift great too and you would feel firms shifts, now 1st shifts a like 5 to 7 mph under light throttle and its hard to tell when the others shifts, shift wtf?....... now at WOT 1st is shifting at 5000 rpm's and 2nd will not shift unless I lift off the go peddle
I have the TV cable set so when the throttle is wide open the cable is at its max can not be pulled any further, I used the govoner out of the other trans but it was moving freely?
RustyD
May 23, 2016 07:04 PM
slimchevy2
Oct 4, 2015 08:02 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
Wolftrk99
Oct 2, 2015 08:17 AM
Silver8ado
Sep 30, 2015 11:42 AM
