6L80E and t case strength...
Old Nov 5, 2013 | 09:27 PM
Atomic's Avatar
I have a gauge for that
Nothing wrong with the 5.3, just dont expect that kind of power out of it with any form of reliability. You might get that power out of it once maybe twice before it destroys itself, if youre lucky.
Old Nov 5, 2013 | 09:28 PM
06chevy5.3's Avatar
Originally Posted by Atomic
I probably have 100+ 1000hp 4wd launches on drag radials with my 5000lb truck and the 250,000 mile stock transfer case looks brand new. Like I said, just dont shift it under power and it will be the last thing to break.
FWIW, the halfton tcase has a max torque rating of 1800ft/lb I think while the 3/4 ton tcase is 2100ft/lb.
Do all the halftons come with the same case I was kinda hoping it was the same case as a 3/4 ton since it has the 6l80e....
Old Nov 5, 2013 | 09:31 PM
gamble686's Avatar
3/4 ton trucks have the 6l90e
Old Nov 5, 2013 | 09:33 PM
Atomic's Avatar
If you look at the back of it you will see a round metal plate on the left side. It has the model number stamped on there.
The manual shift half ton case is an NP 261, the 2500 case is a NP 263. There are a couple others depending on if they are autotrack or electronic shift non-autotrack. Its easiest just to look.
But then I think GM changed the supplier from NP to something else on the gmt900+ platforms.
Old Nov 5, 2013 | 09:42 PM
06chevy5.3's Avatar
well Its definitely pushing the limits... I think it will lift the head from too much cylinder pressure if anything... smaller internals, smaller stroke= less weight slinging around and less stress.... just my theory
thanks... I havent been on here for a while since i took apart my old truck... I have some research to do..
Old Nov 5, 2013 | 09:44 PM
06chevy5.3's Avatar
Ill take a look tomorrow... thanks for the info...
SloSVO
Nov 22, 2020 07:34 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
RustyD
May 23, 2016 07:04 PM
turbo6c3
Oct 5, 2015 06:11 PM
sTNT971
Sep 26, 2015 06:27 AM
