6l80e shift issues when tires break loose?
Old Sep 12, 2015 | 08:01 PM
TAPyvehc93's Avatar
Default 6l80e shift issues when tires break loose?
Do any of you notice the transmission shifting weird (acts confused) when your tires break traction (traction control off)? I heard the tire spin throws off the traction control module causing it to shift weird. Mine sounds like it bounces off the rev limiter before it shifts. Seems fine when it hooks (which is never). Just wondering if I'm the only one having this issue?
Old Sep 13, 2015 | 08:28 PM
Three6GMC's Avatar
Same thing mine does when I'm in 2wd. Bounces off rev limiter for a quick second then shifts. Just tire spin is all.
Old Sep 13, 2015 | 10:46 PM
George C....'s Avatar
Formerly ScreamingL
mine doesnt hit the limiter, it will just spin thru the shift without any issues
Old Sep 14, 2015 | 11:25 AM
Byrdman11's Avatar
When I had the 6l80 in my truck I had to pull all the abs fuses to get the trans and traction control be happy. With the 4l80 Im going to try and tune the ecm to not close the throttle.
Old Sep 14, 2015 | 01:22 PM
Formerly ScreamingL
To prevent closing of throttle is in the tune
Also to shut traction control off is in tune
Oobray
Jun 13, 2022 03:38 AM
LCHEE
Oct 24, 2020 04:10 PM
fastjweb
Aug 15, 2015 10:47 AM
Mark Johnson
Jul 28, 2015 08:56 AM
