6L80 Not Driving After WOT
Old May 6, 2016 | 03:56 PM
Wolftrk99's Avatar
They have plastic *****
Old May 6, 2016 | 04:21 PM
GMCSIERRA5.3's Avatar
^^ what this guy said
Old May 6, 2016 | 11:00 PM
Wolftrk99's Avatar
I have a metric **** ton of factory replacement check ***** and valve body to pump/case seals, everything from gm comes with the same package of 8 checkballs the oump to vb seals and the case to valve body seal and the two o rings and seal for the electrical connector housing adaptor thing
Old May 9, 2016 | 07:39 AM
kaze_v8's Avatar
Just noticed you were in Houston.
You have your own shop?
Ive got the truck at Circle D right now, wouldn't mind swinging by with you, maybe you could shine some more light, if you got to look at the truck?
Old May 23, 2016 | 06:15 AM
CF7GO's Avatar
You ever get this sorted out???? If so......what was it?
Old Jun 18, 2016 | 08:06 PM
07Softail's Avatar
From what I have seen on the 6L80's they will go into limp mode 3rd gear if a lot of slip is detected and yes the checkballs wear down and stick into the separator plate. Torlon ***** are the way to go on rebuilds also if you do a full rebuild go with all of the Sonnax HP 6L80 parts I have had nothing but good come out of these units correcting the leak down issues from wear on these soft AISIN junk Valve bodies. I also rebuild the pressure switches also.
RT
Chevyssr1997
Mar 2, 2016 11:46 AM
tim wellington
Mar 1, 2016 10:11 PM
UnVmy5.3
Feb 23, 2016 05:53 AM
SSpeeDEMONSS
Feb 21, 2016 08:19 PM
