6L80 changing converter. Q-- Rebuild tranny or not to rebuild?
Old Sep 29, 2013 | 06:04 PM
TIM Z's Avatar
11 sec. Truck Mod
Kudos TechGM , we really appreciate your view and advice on this trans . Thankyou !!!
Old Sep 29, 2013 | 06:30 PM
rijrunr's Avatar
Originally Posted by TechGM
I don't think anything crazy would happen because if you manually set shift firmness/soft the trans is just going to do what it is told by your tune. Just make sure it is tuned correctly that way you don't accidentally end up causing more harm than good.
Also remember too that since you changed out that older thinned out fluid with new fluid, the trans will be readjusting shift feel and timing to accommodate that new fluid. Every time a shift happens the TCM looks at it and determines if that was a good shift? Was it completed in an adequate time? Does it need to make fluid pressure adjustments to improve that shift? And so on.
I can notice changes every time I have driven it since doing the work. I supposed I put close to 100 miles after today.
Old Sep 30, 2013 | 09:06 PM
TechGM's Avatar
Registered User
No problem. I hope I can help any and everyone with trans concerns or just general questions. Especially with concerning these newer 6 speeds.
Also just a side note. GM is finally stopping production on the 4L60. So it will not longer be offered in new trucks. And the 2014 CTS is coming with an Aisin 8 speed trans. I know it's a car but I have a feeling that will trickle down to more vehicles and soon trucks with everything so conscious about fuel mileage and emissions
Old Oct 1, 2013 | 05:03 AM
TIM Z's Avatar
11 sec. Truck Mod
Is this not the same manufacter of the Dodge 6 speed in their HD trucks IIRC ? Not a very good trans I've heard . ? ?
It's already sad the Chevy makes the aveo with a daewoo drivetrain , WTF ?
Old Oct 6, 2013 | 06:22 AM
rijrunr's Avatar
I would like to learn more about putting in an aftermarket clutch kit with more disks. Something like PATC offers... Are there mods required? And is there a lot of programming necessary? If it's not a big deal, I'm wondering if I would be better off to spend the money and put them in.
Old Oct 6, 2013 | 06:26 AM
rijrunr's Avatar
Chevy seems to have always had the drivetrain market, but may be slipping a little on the transmission these days. Dodge is ahead in this arena. I hear those 8 speeds are nice. Never drove one.
Old Oct 6, 2013 | 11:59 AM
TechGM's Avatar
Registered User
No need for aftermarket clutch kit IMO. More clutches don't add extra holding pressure. Higher line pressures do. That's it. Don't waste your money on those aftermarket clutch kits on these 6 speeds. Not needed.
Choda
Jan 22, 2026 02:03 PM
Oobray
Jun 13, 2022 03:38 AM
pittman
Jan 19, 2016 07:06 AM
Jake75
Aug 16, 2015 07:06 PM
JordanH
Jul 14, 2015 03:46 PM
