6l80
Old Oct 20, 2012 | 12:54 PM
vVandals909's Avatar
Default 6l80
Are there any marking on the case of the transmission that identifies if it is a 2wd or AWD transmission?
Currently the tail shaft housing is removed from a transmission I was looking to buy.
I need to be able to confirm if it is a 2wd trans and just needs a tail shaft housing or if it is actually a AWD trans and needs a 2wd out put shaft.
Thanks for any help!
Old Oct 20, 2012 | 02:45 PM
Three6GMC's Avatar
I think the output shaft on the trans should give you a good indication of what it is. Post up a pic if you can. I'm sure someone here can help you out.
Old Oct 20, 2012 | 04:30 PM
Here is a picture of the transmission. I believe it is the one in the middle.
http://i809.photobucket.com/albums/z...s909/6l80E.jpg
Old Oct 21, 2012 | 09:59 AM
From looking at the photo can you tell if that is a 2wd or AWD ?
Old Oct 22, 2012 | 10:50 AM
Brian68's Avatar
I can't, but the second digit in the ID tag should be a C for 2wd or K for 4wd, the first digit is the model year. Just look at the large type on the tag. 2 and 4wd are too close for me to tell by a pic. Or I haven't figured out the trick yet.
Old Oct 26, 2012 | 05:22 AM
iamkeniff's Avatar
That trans looks to be awd or 4wd as the transfer case bolts to the back. If it was a 2wd the tail shaft would be longer and the car transmission has an o ring stop for the bolt in yoke with an all thread bolt system machined to the tailshaft
Bumpers
Aug 4, 2024 09:44 PM
TAPyvehc93
Dec 27, 2015 12:14 PM
Chevy305
Sep 28, 2015 09:21 PM
jtphelps289
Sep 11, 2015 06:37 PM
Jake75
Aug 16, 2015 07:06 PM
