-6AN trans lines
Old May 24, 2016 | 11:33 AM
TURBHOE's Avatar
Default -6AN trans lines
anybody running a 4l80e with the -6 fittings on the trans? if so did you use straight hose ends or 90's from the lines to the trans? I had straight fittings on the 60E but I'm thinking 90's may do better for clearance. pics would be awesome.
Old May 24, 2016 | 11:39 AM
oakley6575's Avatar
Definitely not strait. I would do 90's. I think I did one 90 and one 45 degree and i should have used 90's on both of them. I'll try to remember to get a pic when I get home.
Old May 24, 2016 | 11:51 AM
AkSSS's Avatar
My rear fitting is a 90* and my front fitting on the trans is a 45*. It just worked better with running the lines together.
Old May 24, 2016 | 11:56 AM
Atomic's Avatar
I have a gauge for that
I used 2x90s.
tgui's Avatar
Same here, 90 and 45
Old May 24, 2016 | 12:13 PM
TURBHOE's Avatar
Does using a 90 on the front fitting cause the hose to kinda run straight into/toward the bell housing? Not that the hose isn't flexible, but I torn between 45 and 90 on the front fitting. lol I got all the parts I need, shy of the rear drive shaft, to complete the swap. luckily when I did the hoses on the 60E I left enough in length that I don't have to buy new.
Old May 24, 2016 | 12:43 PM
GMCtrk's Avatar
2 90s here, works good
Old May 24, 2016 | 03:48 PM
BlackGMC's Avatar
Resident Retard
i had both, but i ended up using both 45*s...
Old May 24, 2016 | 06:44 PM
1bad2k's Avatar
I did both 90*'s off the 80e too.
Old May 24, 2016 | 08:30 PM
tgui's Avatar
I have an early model with the lines close together.
