Originally Posted by Atomic
(Post 4628433)
4L80E Swap
Trans cooler fittings -6an x 1/4nps $18 Additional Speed Sensor GM 24203876 $19 Speed Sensor Harness 2004sss $20 80e Dipstick Tube GM 15832205 $11 80e Dipstick GM 15183801 $35 Shifter Cable Bracket GM 15013290 $5 Bellhousing Cover Bolts (4) GM 11516328 $4 Bellhousing Cover GM 15765623 $64 Dshaft 5" 69 11/16" Texas DSS $620 PB 4l80e Performabuilt - PB trade difference Performabuilt $920 Torque converter retrofit PI $400 TCI Flexplate 1slow01z71 - TCI-399753 $155 Offset Crossmember Bracket $40 Tcase Adapter 80e to np241 $95 Tcase Pump Saver Thing 4 wheel parts $30 Transfer Case Input tbtrans 42740 $105 Total: $2,541 thats really not bad.. i got the.... 4l80e (junkyard) trans came with... converter (didnt use - still in shed) yoke flexplate spacer dipstick and tube sensor harness - cut it off the donors harness... ended up going speartech - but shoudve repinned it myself bellhousing cover/ and bolts shifter cable bracket other accessories - 750$ for everything speartech harness - 150$ bracket - 0$ homemade with mig machine and some metal we had laying around at work trans lines- cut one of them and added some 3/8s metal brake line and couplings... 10$ from autoparts store segment swap in pcm - 75$ from Futral motorsports.. locally shift kit - installed myself - 120 so total 1105 dollars.. then i bought a 3600 yank converter - 1000 bucks... |
Originally Posted by fredkj3
(Post 4629046)
i was told you can reuse your dipstick and only need a 80e dipstick tube. so far for my swap this wednesday i have
flexplate/spacer long bolts for flexplate dipstick tube yoke 2nd speed sensor modded crossmember tranny lines off a 2500 surburban a 4l80e and converter dustsheild and shifter cable bracket and everything else came on tranny. |
Originally Posted by BadAssChevy327
(Post 4629167)
(Post 4629167)
