6 lug 14 bolt
If you are making enough power to need the 14b...then upgrade your driveshaft and convert to 1350 u joints. Don't go cheap now and regret it later.
As for the brakes, they will bolt up...but the calipers will be "clocked" due to the angle of the brake flange. Functionally, there should be no difference.
So far I'm at 627 whp, 653 tq, but I plan on turning it up with a bigger turbo next spring.
Sooooo, a DS from a 3/4 ton, or have one made? Is the front yolk where it goes into the transfer case the same?
No Brent, dont get a stock 3/4 shaft!
They arent stronger,same thin alum just bigger od than the 1500 shaft.
I was wondering about using a duramax rear shaft when i did the 80e conversion, but found that its the high speed critical rating that makes it a bad choice.
Just get another steel one!
I can get ya balanced steel shaft made with your yoke for 273 here if it would help ya.
Gonna try and run at quaker city this weekend since sat. work was canceled.
It would be cool if you could make it/weather cooperates.
Thats awesome man! I gotta do this mod during the winter!
Let me know when you are going, and I will try to make it, but I'm not promising yet.
Mine is a steel shaft, I think it is 3", and am not worried about the strength at all. If I get a new shaft, shouldn't I get one with a heavier front and rear yolk/u-joint?
Yes....I used a bastard joint when I first did my 14b swap and had a ujoint failure at 75mph and did this:
the skid plate was the only thing keeping it from falling onto the highway...
