6.0/4l80e owners, please step in
Old Feb 20, 2011 | 10:32 PM
SmokinHot98's Avatar
Default 6.0/4l80e owners, please step in
I did an LQ4/4l80e swap back in October, and the one thing that seems to bug me is. Is it normal for the truck to bounce in and out of 3rd and 4th when not under load/throttle?
If I keep light throttle the truck will stay in OD, but if I let off it comes out. Then I apply throttle again it goes back in and so forth. It sucks because everytime I hit a bump and my foot slightly raises off throttle it shifts in and out.
Old Feb 20, 2011 | 10:36 PM
Atomic's Avatar
I have a gauge for that
Are you sure its not the torque converter unlocking?
Old Feb 21, 2011 | 12:00 AM
it may be, but I'm not sure. I swapped all the 80e tune segments from a stock 04 2500 and never changed anything. Is there something I should look at there or could it be the TC itself? It bugs the hell outta me
Old Feb 21, 2011 | 12:04 AM
I was having an issue with this awhile back
P2761 = Torque Converter Clutch Pressure Control Solenoid Control Circuit/Open
supposedly changing the ignition switch would fix it but its still there
GMCtrk's Avatar
its the tc unlocking.
Old Feb 21, 2011 | 12:09 AM
so replace the TC?
I want to get a circle D but can't afford it right now
Old Feb 21, 2011 | 12:18 AM
smokeshow's Avatar
Mod with training wheels
I get a weird lockup as soon as I shift to 4th and it unlocks again right away, but I'm sure its a setting in the tune. What you're explaining sounds very similar.
Old Feb 21, 2011 | 12:23 AM
exactly, its just weird.
Old Feb 21, 2011 | 12:24 AM
amadeospike's Avatar
its the tc locking and unlocking. It unlocks in decceleration and lock in acceleration im not sure if it can be changed with the tune. I need to look at the tables. in the 60e it unlocks when u step on the brakes
Old Feb 21, 2011 | 12:25 AM
GMCtrk's Avatar
it can't be tuned out. Only way to prevent it from unlocking at 0% is to use the 60e tune and make wiring mods to the trans.
