6.0/4l80e 2wd to replace a 5.3/4l60e 4wd
Old Jun 26, 2010 | 11:52 AM
2000halftontank's Avatar
Registered User
Default 6.0/4l80e 2wd to replace a 5.3/4l60e 4wd
I own a 2000 1/2ton 4x4 silverado with a 5.3 and a 4l60e. I have a donor 2001 3/4 ton with a 6.0 and a 4l80e but its 2WD. The donor truck is complete, just a little wrecked. I still want to keep my truck 4wd. what is needed to convert the 2wd drivetrain to 4wd? and the 5.3 to 6.0?
Old Jun 26, 2010 | 11:53 AM
stevenc's Avatar
you need to open up the transmission and swap out the output shaft, you also need to modify the cross member and drive shaft. do a search there is a ton of 4l80e swap threads.
Old Jun 26, 2010 | 02:17 PM
Registered User
so its going to put my transfer case back further. that means that both driveshafts have to be replaced.
Old Jun 26, 2010 | 05:24 PM
stevenc's Avatar
i recall only the front one needing to be modified.
maxspeed05V
Nov 11, 2015 04:20 PM
Fast86z
Aug 23, 2015 12:35 AM
97aztecgt
Aug 13, 2015 02:11 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
85SS/85GN
Jul 22, 2015 12:48 PM
