525 rwhp 4l60 problems
Old Jan 7, 2016 | 11:25 PM
  #21
andrew88's Avatar
Originally Posted by Z71crawford
Look up transbuilder guy and be done with all your problems.
i looked him up and and it would likely be the route i would go except my trans is under warranty right now for its current build, but its on me for more upgrades. so im kind of stuck at the moment working with what i have.
Originally Posted by Dylpicle8
I seen 25 HP and the title and thought you were pushing it for a 4l60e.
Then I re read and seen 525! That's about 28x too much for a 4l60!
All jokes, Billet drum upgrade would help with the 3-4 drum deflection under pressure and probably help your problem, but I always like to see 80e swaps
thanks for the input. as i said previously im trying to figure out how to get there with what i have going, an 80 sounds good, but i guess in theory a built 60 should be just fine also
Old Jan 7, 2016 | 11:32 PM
  #22
andrew88's Avatar
my builder told me he has:
-Alto clutches
-Alto band-
-Corvette servos
-the Beast sun shell
-Transgo shift kit
Old Jan 8, 2016 | 12:12 AM
  #23
Dylpicle8's Avatar
Look into a Billet pump rotor as well, I'm guessing the extra pressure being built from the shift kit caused mine to go bang from a launch last winter. Some better input or output shafts (I forget which is the weak link) would probably go a long way. I prefer the Borg Warner high energy band and clutches, they seem to hold up better, absorb more fluid and run cooler. Sonnax and some other brands offer servos which are supposed to apply better than the vette servo. Other than that I hope the 4l60 works out for you.
Old Jan 25, 2016 | 02:59 PM
  #24
Tigger Welder's Avatar
I did the beast sun shell 5 pinion planetaries, shift kit, vette servo, and something else that won't come to me. Builder said, DO NOT BUILD A 500+ HP motor and put it in here, it WONT LAST!
Old Jan 25, 2016 | 03:03 PM
  #25
TXsilverado's Avatar
If you decide to stick with a 60e, check out the one ihave posted in classifieds. Its as built as they come with one of the best names doing the build.
Keithstir
21
Nov 24, 2015 05:24 PM
DAH32
Nov 13, 2015 01:28 PM
marlboroman71818
Nov 9, 2015 02:03 PM
