4x4 guys with stall's
Old Jan 12, 2006 | 03:35 PM
98TAauto's Avatar
Default 4x4 guys with stall's
im still thinking of getting the TB stall for my 04 ECSB 4x4... since adding the 210/218 cam and no cats ive got crappy low end below 2500 rpms.. above and the truck is sweet
i dont have the 500-800bucks for yank stalls and etc so i was wondering how everyone likes the tb stall and how well its holding up? This is my daily driver also..
any thoughts and opinons are welcome
Old Jan 12, 2006 | 03:54 PM
Bad_Apple's Avatar
If you don't do alot of towing I would slap like a Fuddle 3000-3200 Stallin there to help bring that big truck out the hole. But if you do alot of towing with it I would go witha TB stall.
Old Jan 12, 2006 | 05:15 PM
Zick's Avatar
I'm loving the TB stall.
Old Jan 12, 2006 | 05:38 PM
seeyaa's Avatar
i have a 3000 tci in my Z and man is it fun a little loose but not bad. I also drive mine every day i also tow. but i did brake 3-4 in my 60e but it dose have 80000 hard miles on it.
Old Jan 12, 2006 | 05:52 PM
thunder550's Avatar
High on diesel fumes
What kind of cam is that? I put in a Vinci 210/218 and I have loads of torque with the stock stall, although I do have the Radix. You are N/A?
Old Jan 12, 2006 | 06:31 PM
Wilde Racing's Avatar
How do I change this text
Does the Fuddle slip with a heavy load?
Old Jan 12, 2006 | 08:25 PM
98TAauto's Avatar
its the Vinci 210/218 114 cam.... i have loads of low end above 3k, but the lag getting to those rpm's suks. Yes im NA also...
The only thing i tow is a little trailer with a 4wheeler on it, but thats rare also...
Old Jan 12, 2006 | 08:38 PM
getchusum99's Avatar
im wonderin the same question about the tb converter, i have a 4x4 also and am in the process of rebuilding it AGAIN. how much is the stall? and how much will it dampin my tranny life???
Old Jan 12, 2006 | 08:53 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
A TB converter will work fine. I had a TCI3000 in my truck and towed with it and drove it everyday and it was fine. I have had one Fuddle in my truck and now Im going with a higher one for my 418. A Fuddle converter has ALOT larger lock up clutch than any other converter on the market.
Old Jan 12, 2006 | 08:55 PM
1slow01Z71's Avatar
Going with a 3200 btw John from Fuddle can put a different stator in there to make it feel "tighter" for you. Thats what he did for me.
