4x4 to AWD
Old Apr 8, 2009 | 11:03 PM
Just my opinion though.
Old Apr 9, 2009 | 08:12 PM
1Bear's Avatar
Originally Posted by fastlt1
Which is stronger ss silverado drivetrain or autotrac 1/2 ton 4x4 drivetrain?
AWD NVG-149 = 2203 ft. lbs rated Max Capacity Torque
Auto-Trac NVG-246 = 2281 ft. lbs rated Max Capacity Torque
Manual Shift NVG-261 = 2563 ft. lbs rated Max Capacity Torque
Auto-Trac 3/4, 1 Ton NVG-263HD = 5430 ft. lbs Max Capacity Torque
Manul Shift 3/4, 1 Ton NVG-261HD = 5430 ft. lbs Max Capacity Torque
The front differentials are both 8.25" assemblies and the only difference is the AWD units have a one-piece passenger side axle. All in all, the front diff from the AWD may be slightly stronger due to the one-piece axle, while the Auto-Trac is rated the stronger of the two transfer-cases. I believe if I already had the AWD transfer case, I would stay with it. If I had an Auto-Trac case and wanted something stronger, then definitely the NVG-263HD would be a great upgrade.
Old Apr 13, 2009 | 01:06 AM
is the 3/4 ton tcase a direct swap for the 1/2 ton?
I dont suspect it to be, but it would be a nice upgrade.
I have a floor shift fwiw...
Old Apr 13, 2009 | 11:00 AM
fastlt1's Avatar
12 Second Club
Electronic wise would the Auto-Trac 3/4, 1 Ton NVG-263HD be a direct swap for the Auto-Trac NVG-246 ?
Old Apr 13, 2009 | 10:29 PM
1Bear's Avatar
At a minimum the NVG-263HD is designed to go behind at least a 4L80E. So without an input gear change, it wouldn't connect up to a 4L60E. It would be an excellent opertunity to jump into an 80E though.
AdaMax
May 16, 2016 11:35 PM
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
