4WD transfer case delete help!!!
#21
Stator of oil pump that used to be held very well with sealant at the joint rattles its way through the case on the newer 99 up units with 1 pc rear section. Not a horsepower thing but a mileage/internal vibration issue at the pump. Your tailshaft will be soaked with oil and there will be a very small pinhole if you have this issue. I have a takeout 67,000 mile t-case for a 99 in the mass parts forum if anyone is interested, located in WI.
#22
Mine had 150k+, and the clip was broken when I changed the input and chain for the 80e swap. It had a little wear spot but was not bad enough to worry about. The new clip is at least twice as thick, but doesn't rivet to the case like the old one.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
