4wd launches
Old Jun 18, 2014 | 05:49 PM
lsxperformance's Avatar
So how you guys keeping front cv's level. When launching mine squats and raises the front bad. You both strapped down or what?
Old Jun 18, 2014 | 06:13 PM
Atomic's Avatar
I have a gauge for that
Coilovers
Old Jun 18, 2014 | 07:57 PM
Pretty awesome! I'll read up on them and go from there what are we talkin weight savings wise here? Probly 100lbs at least.. I'm guessing? What you guys doin on the rear? 4 link, caltracs.. Etc. or not messin with it at all?
Old Jun 18, 2014 | 10:04 PM
Atomic's Avatar
About 30 pounds....the tbar stuff really isnt that heavy; about 72lb total.
Rear is stock with assassin traction bars and rancho shocks.
Old Jun 19, 2014 | 04:45 AM
TIM Z's Avatar
11 sec. Truck Mod
Yeah , Atomics coil over setup would be the way to go for sure
But for your question on angles , it's easy , you just need to make sure your CV shafts are as flat or close to flat ( level) as possible , that will give them the travel they need up or down when launching /driving/ ect ,
When the front is level , the components have a better chance of surviving .
Also guys on here strap their front end at the track , I haven't yet but want to ,
03SierraSLT has a sweet strap setup on his Denali.
Old Jun 19, 2014 | 06:56 AM
Atomic's Avatar
I used to have mine strapped, but it rode like **** so thats why I made the coilovers
Old Jun 19, 2014 | 12:12 PM
thunder550's Avatar
High on diesel fumes
My front angles are slightly negative (higher at the wheels). I'm thinking that they flatten out when I launch. No problems so far, even with the Duramax in the half ton.
Old Jun 19, 2014 | 09:52 PM
Moneypitt's Avatar
This is my 09 with a 12 psi boosted launch.
13 10@102 Front End - YouTube
Old Jun 28, 2014 | 10:52 AM
darnie's Avatar
Not to thread jack. But when u guys run do you leave it in 4x4 the whole pull?
Old Jun 28, 2014 | 11:58 AM
Atomic's Avatar
Yep. Most likely to break something if you try to shift out under power.
