4wd 4l80e in a 2wd
Old Jun 10, 2016 | 11:24 PM
Nwfjarhead's Avatar
Is this a good time to add in a trans brake or is it very involved to do it at a later time? Is there any issues or weird things that have to be done in order to run on the street with a trans that has a brake?
Old Jun 11, 2016 | 08:20 AM
Wolftrk99's Avatar
Where are you located, i may have a simpler solution for both of us....
Old Jun 12, 2016 | 12:25 AM
Nwfjarhead's Avatar
Fort Walton Beach Florida. What do you have in mind?
Old Jun 12, 2016 | 12:30 AM
Wolftrk99's Avatar
I have a 2wd trans, need a 4wd and you are coming into an opposite situation.... If youbwere closer id say we could swap transmissions, but shipping from florida on a trans is as far as i know about $150....
Old Jun 12, 2016 | 01:57 AM
Flewbyu123's Avatar
Reluctor ring?? Which one??
4wd gets its speed from the transfer case.. if you don't add the reluctor ring back the same as 2wd .. Will not keep the correct speed and will not shift gears in the tranny.. I know had this problem myself..
Old Jun 12, 2016 | 07:36 AM
Wolftrk99's Avatar
Thought that was just the earlier ones, and that the oss ran off of the parking pawl reluctor pn the rear planetary...
Old Jun 12, 2016 | 08:59 AM
Flewbyu123's Avatar
The one I have is off an 2003 and i had to add the reluctor ring to the rear planetary... How you can tell mine had a blank oss plug in the rear, added sensor still had no real mph reading, stopped around 20 mph tranny only shifted if I let off the gas... Even went back to the tranny shop no one caught it... Read it on the LS site, pulled the oss plug looked, no reluctor ring . Took me over a month to find and I was one mad MF at the transmission shop!!!
i
Old Jun 12, 2016 | 10:59 AM
Wolftrk99's Avatar
Hell that wouldve been first thing id have checked was iss/oss sensor readings and wouldve swapped sensors, then when i still didnt have an oss reading them id have looked inside... Lol!! But i have seen 4wd 4l80 with the reluctor in place, unless someone replaced the planetary and didnt transfer the ring, whoch is entirely possible....
Old Jun 22, 2016 | 09:20 PM
Nwfjarhead's Avatar
Well I picked up the trans last night. Now to decide what to do with it.
Old Aug 5, 2016 | 12:22 PM
Nwfjarhead's Avatar
Would you still be interested in trading if I cover shipping?
