4L80E too much transmission?
Old Dec 17, 2015 | 03:35 PM
Tig's Avatar
Tig
Default 4L80E too much transmission?
I keep bringing up to a friend about doing an 80e swap in my 07 Tahoe.
Every time he says "its too much transmission for your truck". He never really elaborates or explains his meaning but always says the same thing.
Why would it be too much transmission?
Thanks
Old Dec 17, 2015 | 03:41 PM
Fast355's Avatar
I prefer the 4L80E to most GM transmissions, except maybe a TH400 with a GearVendors on the back of it. The only thing I need to change with my 4L80E swap setup is to put a lower rear-end gear in it. Need to drop it to a 4.10 to run with my 29" tall tire setup. I just bought a 2,600 rpm stall 10.5" converter for the 80E too. Between the two changes it should really eliminate any performance loss from the 4L80E.
Old Dec 17, 2015 | 03:45 PM
tgui's Avatar
What does *he* mean by "too much transmission"?
NM fully read your post.
Old Dec 17, 2015 | 03:50 PM
tgui's Avatar
I'm trying to finish my 4l80e swap. I did it because I never want to worry about my trans again when I throw a turbo on. That and its a fun hobby to put one in for me (so far).
There are downsides.
- $$, gotta collect a number of parts. Driveshafts, converter, cross member....
- Time, there are a few supporting mods.
- Gotta get a tune if you want to avoid the relay setup, which I hear isn't always perfect.
- If you worry about weight, it weighs more.
- 1st gear is tall.
If you're not making crazy power and drive like a sane person, a 4l60e can be just awesome.
Old Dec 17, 2015 | 06:45 PM
Tig's Avatar
Tig
Maybe he's talking about the whole first gear thing. I don't know.
I figured I could get a stall, something like a 3400 and it should be good.
Thoughts/ opinions?
That's my point. I don't want to worry about my trans again.
My future plans are a 6.2.
I do drive a little more spirited in the AM and more like a sane person on the way home. But, I do like to get on it and don't want to have to worry about it.
Not worried about weight
As long as I can find the right dimensions for the driveshaft, I'll cut it down.
Cross member, I'll do that to.
Money, its coming in, slowly, haha.
Old Dec 18, 2015 | 02:26 AM
BlueTexan24's Avatar
GM should've put 4l80e trannys in every v8 engine combo for a truck, yeah the first gear is longer but the peace of mind is way better than a 3.06 first gear. Some guys have actually gone faster with an 80 swap cause the 1-2 shift keeps the rpm's higher than the 60e.
Old Dec 18, 2015 | 02:28 PM
Fast355's Avatar
^^^ I just had a Phoenix Transmissions 10.5" converter installed in my Express van that has a 4L80E in it with 3.73s. With a GM 300hp 350 marine cam in the 350 it pulls very well everywhere in the power band.
GM put the 4L80E behind some 4.3s.
Old Dec 18, 2015 | 03:04 PM
walledition's Avatar
a friend of mine who ownes a yunkyard said i was crazy when i told him i was swaping to a 80e, he said its big heavy and slows down your truck, reason he said it was all the 6.0/4l80e stock trucks he drove where slow, he claimed it was a towing transmission
He saw he was wrong once everything was back together and tuned
Old Dec 19, 2015 | 12:10 PM
Tig's Avatar
Tig
I agree.
Where can I find or what should I type in to find the different ratios for each trans?
What stall?
I was thinking something like 3200. I had one in my previous Tahoe, that and the built trans was awesome. Drove like a champ.
I had an 04 HD 6l/4l80e, I wouldn't say it was slow.
I'm hoping for the same drivetrain in my 07 Tahoe, that should be fun.
So, what do you guys suggest I do?
Stall? If so what should I go with? 3400 sound good?
Is it still going to be street-able, it is my daily.
Old Dec 19, 2015 | 12:27 PM
Fast355's Avatar
Originally Posted by Tig
I agree.
What stall?
4L60E
3.06
1.63
1.00
0.70
4L80E
2.48
1.48
1.00
0.75
The Phoenix converter was built to be a tight 2,600 behind a mildly cammed 6.0L with the intention to spray and be around 3,400 rpm on spray. Behind my small cammed 5.7 Vortec it stalls more like 2,800-3,000 rpm. Its pretty loose in my setup. At idle of 750 rpm it does not even creep forward in gear. To get my 6,200 lbs rolling, you have to open the throttle 10-15% compared to the stock converters 2-5%. When I get a little aggressive on it I keep finding myself laying lots of rubber down and a cloud of tire smoke behind me.
