4L80e swap parts list
Wanted to doublecheck the parts list for the 80E conversion. I have the converter, transmission, conversion harness from PCM of NC, crossmember from dirt track racer, drive shaft yoke. is there anything else I need? Can I use my factory dipstick?what about the transmission cooler lines? Thank you!
Need the 4l80e specific dipstick tube. Fluid level must be checked in relationship to the transmission case, NOT the dipstick markings.
Transmission cooler lines depend on what year the 80e is. If it's pre 97, you can use your stock lines. If it's post 97 the rear line needs to be extended. But, ideally you need an aftermarket transmission cooler and AN hose makes the routing very easy.
If you have a 97 up transmission and do choose to use AN fittings for the cooler lines, the rear port must be the correct fitting or else you will burn up the trans guaranteed.
What do you mean I have to check the fluid level as compared to the transmission case not the dipstick markings? Why couldn't I use the dipstick markings? Also the drive shaft yoke is off of a driveshaft that came with an 80, I don't have a part number however are you looking for one?
Just get a 80e disptick. The ujoint for the conversion is a napa 447 precision. Now i just installed a 80e on my tbss. I got the yoke with the trans and its alot wider than the original yoke. Took some looking and found the u joint for it. Its a neapco 2-1435. 1410X1350 but your driveshaft i believe is a 1310 stock. So measure and see what joint u need. The 447 is a 1350x1310 joint.
